GRA108
Message 1 of 1
Configure Home Hub 5 Ports
I have an issue where a device keeps losing connection to a server on the Internet.
The advice from the Solar edge help desk is to add or check the following port configuration
Make sure that the following ports are open:
TCP ports 22222, 22221, 443, prod.solaredge.com, prod2.solaredge.com
I believe this should be some where in the port forwarding configuration .
When I go into advanced setting port forwarding I can see where to add a new application  and where to add the ports,
but not where to add the "prod.solaredge -----"    any help on what to do or indeed how do i check that these prots are open.
