Chubba
Message 1 of 2
Configuring Whole Home WiFi to Smart Hub WiFi
Hello
I've set up a Mini Whole Home WiFi with three discs and most recommendations I've read is to disable the Smart Hub's WiFi to eliminate interference or prevent existing devices to still connect to the Smart Hub directly.
However, I've changed the network settings of the Whole Home to match what my Smart Hub's is.
In this scenario is it still recommended that I disable the WiFi of the Smart Hub?
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: Configuring Whole Home WiFi to Smart Hub WiFi
Hi @Chubba  It would be best to check with the WHW team.
You can contact them on the phone: 08081006116 Mon to Fri 9.00am to 5.30pm and Saturday 9am to 2pm.
Or by email: btconnectedhome@bt.com
cheers
John
