stitch666
Message 1 of 2
Connect Wholehome discs to router or Sky Hub?
Hi everyone,
Quick question.  I have a sky hub 2.0 and a seperate Dlink router.  The reason for the router is I use it as a switch for more ethernet ports.  Am I better off connecting the first Wholehome disc straight to the Sky Hub, or to the Dlink router?
 Thanks in advance.
1 REPLY 1
Message 2 of 2
Re: Connect Wholehome discs to router or Sky Hub?
You asked a similar question here https://community.bt.com/t5/BT-Devices/Whole-Home-Mesh-and-extra-DLink/m-p/1901443
As this is a BT Retail customer forum only, you are very unlikely to get a reply, so I suggest that you post the question on the Sky User Forum.
Sky User - The unofficial support forum for everything Sky!
Remember that this product is intended for use on all providers, and the configuration would be different for each provider.
