Message 11 of 20
Re: Contacts Database of Phone Numbers
I did and I religiously corrected the vcf file opened in Apples Notes.
I’ve spoken to Apple but they’re not really able to help. I have a corrected Notes file, but I cannot see how to get those changes back into a vcf file. The Notes file is saved but how do you get converted into a vcf file. Goggle says import into Apples Contacts file and then export that as a vcf, but I can’t see how to do the importation. I’m also concerned about the space between the area code and the number, Apple defaults to creating the space.
Message 12 of 20
No idea about Apple devices, they do things differently to everyone else.
Editing in notepad with Windows is a doddle and just works. Save the file with .vcf extension.
Message 13 of 20
Thanks, I still have a Windows machine. I’ll see if I can navigate as you’ve suggested. Thanks again!
Message 14 of 20
I've just checked my contacts in notepad.
Not sure of the relevance of the semi colons (;) after the surname, but I only have 3 rather than the 4 shown in the other thread.
Message 15 of 20
Well although I tried to remove the space between the numbers, the vcf imported the numbers WITH the space OK and appeared correctly in the phone listing, although I’ve yet to actually dial a number using the database. As I’ve said already it’s the editing that fouls everything up! Hey Hoy
Message 16 of 20
When I created my contacts list on moving to Digital Voice, I created the first contact using the supplied DV handset and then simply used that as a template, editing it with all the rest of my contacts in Notepad.
The syntax is exactly the same as that posted with the exception of the number of semi colons as previously described.
Are you sure you are using colons rather than semi colons in this part TYPE=home:tel:home_tel
Message 17 of 20
Thanks…..I’ll take another look tomorrow afternoon using my old windows machine……
Message 18 of 20
Update:
was able to correct and save the files as indicated using the Windows machine. Checked that the corrections had been saved. Imported to BT hub.
some of the records included more than ONE telephone number but, as before, only ONE appeared in the directory.
only improvement: although the edit record still didn’t work, this time it didn’t crash the database.
solution: just have one number per person???!!
Message 19 of 20
Just as amazing..,,,,tried to edit one contact by adding a second number and it correctly added it.
but when I immediately tried a second contact it reverted to saying it was saved but no second number appeared.
Message 20 of 20
Having had exhausted conversations with BT Executives Office, I’m wondering just how many users of an imported cvf,  created telephone number database on a BT Digital Voice Hub, have managed to import multiple numbers per person and carried out successful editing?
