marco63
Message 1 of 3
Definition of ‘strong’ with regard to Complete WiFi coverage
I am considering the offer that BT have sent me for an upgrade for the Complete WiFi service
I currently have no coverage in one room and weak in two others
The term ‘strong’ is open to wide interpretation - is there any technical data available of what BT consider a strong wifi signal?
Marco
2 REPLIES 2
Message 2 of 3
Re: Definition of ‘strong’ with regard to Complete WiFi coverage
Because wireless signals can suffer from interference and  be blocked by the structure of your home all of which are out side BT's control I doubt you will find any definitive answer for what a strong signal is.
BT do however state that you will get a "strong" signal in every room and if not they will send you a further two discs to achieve that.
I would say that if you are measuring the signal strength you should expect to get between  -65 to -70dBm
 https://home.bt.com/tech-gadgets/internet/broadband/what-is-complete-wifi-bt-broadband-bt-plus-11364...
https://home.bt.com/tech-gadgets/internet/broadband/how-to-boost-your-home-wi-fi-11363806366107
EDIT:
BT have this in the small print
Complete Wi-Fi guarantee
96% UK availability. BT sends additional discs to guarantee at least 10 Mbps in every room of your home. Sky send one additional disc and guarantee 3 Mbps or money back. No other provider offers a faster Wi-Fi Speed Guarantee than BT. To verify e-mail superfast.fibre@bt.com.  We’ll send you up-to three discs to ensure a strong signal of at least 10Mbps in every room of your home. If you still can’t get a strong signal we’ll give you a one-off credit of £20 off your next BT bill. Guarantee only applies when your Smart Hub2 is connected to the internet and does not cover broadband faults. For full terms see bt.com/legalstuff.
https://www.bt.com/broadband/complete-wifi?s_intcid=con_intban_dmedia_content_Tech_Storefront_boost_...
marco63
Message 3 of 3
Thanks bud - very useful
