Peterhill87
Message 1 of 6
Deregister handset bt3570
Hi, I can't deregister the faulty handset from the base and I can't register my new handset until the faulty one has been deregistered? Help!
5 REPLIES 5
Message 2 of 6
Re: Deregister handset bt3570
Hi @Peterhill87   You could try the product helpdesk (when they are open)
Product helpdesk information
If your phone is within warranty:
By phone: 0800 145 6789
Monday to Friday 9.00am to 5.30pm, Saturday 9am to 2pm
By email: Click here for email support
If your product is out of warranty contact BT's recommended agent
By phone: 0800 980 8999
Moderator
Moderator
Message 3 of 6
Hi @Peterhill87
Welcome and thanks for posting!
Sorry you're having problems with the handsets.  Your best bet would be to chat with product support using the contact details above.  Thanks @VeteranISPUser  Smiley Happy
Cheers,
Robbie
Peterhill87
Message 4 of 6
Hi, many thanks for your prompt reply, after trying various solutions I contacted support who directed me to a premium number.
Peterhill87
Message 5 of 6
After a lot of head scratching I tried one of the other working handsets and I was able to deregister the faulty handset from there.
The new handset had problems registering with the main base, but after a few hours I tried pressing the find button on the base unit until the blue button was flashing (registering mode not obvious in the instructions) and then registered the handset, phew!!
Moderator
Moderator
Message 6 of 6
Great post there @VeteranISPUser . Kudos to you Smiley Wink
Glad to hear that sorted everything for you @Peterhill87 . Post back if you have any other problems.
Cheers
David
