Hi - I’ve noticed that I have devices showing incorrect connections. A number of devices are showing as Ethernet icon and then when I click on the device and scroll to to the bottom it says connection is Ethernet when it’s connected by Wi-fi.
Is there a way to change this?
Hi @chucky_uk do you have discs or wifi extenders connected to your Hub? If you do then devices connected to these can show up as connected via ethernet.
