Is there any difference between the black disk with the "BT "and the BT coloured globe symbol and the disc with just the "BT" in a silver circle?
Solved! Go to Solution.
no just the new stock with new BT symbol as against old stock
there is a post exactly this already https://community.bt.com/t5/BT-Devices/Different-style-design-of-black-WiFi-discs/m-p/1976889
the newer version is the one with the new BT logo - circle with BT apart from that same
Hi, will both the old and new discs work exactly the same with BT smart hub 2?
