Kingmerrill
Message 1 of 2
Disc 2
I'm having troubles connecting my BT disc 2 to my BT Hub 2. I'm not connecting via the app I'm using the ethernet method. When the disc is connected to the hub via the ethernet cable I eventually get a solid blue light which according to the BT disc 2 manual means the disc is connected. However when I disconnect the ethernet cable from the disc the light starts reverting back to flashing red and not a solid blue light.
Any reason why this is happening?
1 REPLY 1
albertj
Recognised Expert
Message 2 of 2
Re: Disc 2
Hi @Kingmerrill
Welcome to the Community!
Is this the second disk you’re trying to pair, or the first? Are you paying for complete wi-fi? Is the disk black?
You could try connecting by factory resetting the disk - and press the WPS button on the Hub and Disk to pair.
Failing that, factory reset everything and try setup again.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
