TerribleWifiMan
Message 1 of 6
Disc wont connect
I have the BT whole home wifi range extender kit for my house, all 3 discs were functioning correctly until one of them was plugged out, after it was plugged back in, the disc will not connect to the wifi or to either of the other discs, I have tried factory resetting and turning it on and off again until its connected but the light stays purple. I am unsure what to do
5 REPLIES 5
NeilO
Moderator
Moderator
Message 2 of 6
Re: Disc wont connect
@TerribleWidiMan, can you try factory resetting all the discs then follow the setup guide to connect them back up? If you need further help the Whole home wifi helpdesk can be contacted on the below details.
By phone: 0808 100 6116
Monday to Friday 9.00am to 5.30pm
Saturday 9.00am to 2.00pm
By email: btconnectedhome@bt.com
TerribleWifiMan
Message 3 of 6
Will try that and get back to you on that! Thanks!
Siclarke
Message 4 of 6
I have very similar problem. One disc won’t connect. Have had discs for over a year. Non connecting one has purple light constantly on despite doing factory reset & trying to re-connect directly with home hub etc.
Stuck for ideas now?
DavidM
Moderator
Moderator
Message 5 of 6
Hi @Siclarke,
Thanks for posting. Have you tried the help desk as per @NeilO post?
Cheers
David
Siclarke
Message 6 of 6
Hi David.
Thanks for your message.
Have already sent an email to the address he’s listed and waiting to hear back.
Bit wary to factory reset my other 2 functioning discs when it’s not worked for the original faulty one, (as don’t want to b*gger them up too...)
Cheers.
Simon.
