Mustafa_Islam
Message 1 of 7
Do I ‘need’ to return my old router?
I got a replacement bt hh6 for a damaged hh6. The box the replacement came in said to use the box to return the old one to be recycled.
My question is do I have to return it or can I keep it? I was thinking of turning off the dhcp and make it into an access point. If I keep it will I be charged at all?
Thank you. Also if it’s possible can we get a mod to get involved? I feel like replacement should come with a new dsl cable too.
____________________________
If I helped out then leave my reply a Kudos by clicking the thumbs up button
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: Do I ‘need’ to return my old router?
You do not have to return it, BT have to offer that option, see https://www.gov.uk/electricalwaste-producer-supplier-responsibilities
Sending a new DSL cable would be wasteful, as its not normally needed.
Mustafa_Islam
Message 3 of 7
Great, so if I keep it I won’t be charged?
Keith_Beddoe
Message 4 of 7
That is correct, as its no use to BT.
Mustafa_Islam
Message 5 of 7
Thank you very much for this information 🙂
Hope it helps others in this situation
Mustafa_Islam
Message 6 of 7
I contacted BT with the live chat and asked them if I am allowed and will there be a charge and they did confirm it’s fine to keep it to recycle or reuse for my own without being charged. He also added a note on my account for future enquiries of replacement hubs.
gg30340
Message 7 of 7
Glad to hear that you got it confirmed that the information you were given on the forum was as always, correct.
