williamboy
Newbie
Message 1 of 2
Doors open on cabinet no 14 shirley southampton no sign of bt staff
Doors open on cabinet no 14 shirley Southampton
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Doors open on cabinet no 14 shirley southampton no sign of bt staff
Hi @williamboy,
Thank you for posting.
You can report this directly to Openreach using the link Openreach get in touch.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
