Message 1 of 4
Dual WiFi dongle 600
My dual wifi dongle 600, on a windows 7 pc, keeps dropping out the 300Mbps channel leaving just the 144 channel. I need  to download some update files, onto a USB device, but it’s offering 4 hrs download time at 144 Mbps. I have gone through the set up procedure again to no avail, and I seem to have the latest driver version. Has anyone had similar experience, or can advise?
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Dual WiFi dongle 600
What package do you have? Unless it's FTTP or GFast then even 144Mb is likely to be double the download speed of your connection.
Message 3 of 4
We are still on FTTC. If I unplug the dongle and then reinsert it, the faster channel shows in the network settings, but if I try to download it simply disconnects and disappears from the list of networks.
Message 4 of 4
You can only download at the speed of your broadband, it doesn't matter what speed the wifi is.
