Message 11 of 13
Re: Dual band Wifi Extender 600 change SSID???
Because once you know its IP address you can log in to it directly by entering the address in your browser address bar.
It will be a 192.168.1.XXX address, you can discount most of the addresses by ones that show up in the hub manager network list that are other devices.
Message 12 of 13
Ah ok I've figured out which one it is and I've logged into the extender settings
Message 13 of 13
I've now sorted it out. Thank you all for your help 🙂
