Message 11 of 18
Re: EE Smart Hub - Nolonger able to access hub over https using Safari on macOS
See above. If you do not understand the post, please refrain from commenting.
Message 12 of 18
If you are not prepared to use another browser you will need to post on the EE forum and try and get a response that suits your needs because the only further response you will get on the BT forum is a repeat of what has already been given.
Tags (1)
Message 13 of 18
@gg30340
Please refrain from posting if you have nothing to add to the topic.
Message 14 of 18
As this is a public forum I can post on any thread that I choose whether or not you think it adds to the topic.
It would be better if you refrained from posting further as your post has nothing to do with this forum.
I will repeat as you appear unable to comprehend that this is a BT forum and NOT the EE forum which is where you should be posting your "issue".
Message 15 of 18
@Sulla Please refrain from posting about EE problems on a BT forum.
The problem would appear to lie with Apple in any case.
Message 16 of 18
@Sulla
Sorry for the delay.  Been out to do the shopping.
Unfortunately, it would appear you are the one that does not understand certification.  A certificate has two roles.
In the first case, the self-signed certificate does what any certificate does.  It provides a means of generating a session key so the traffic can be encrypted.  Irrespective of whether it is internal traffic or not.
What it does not do is the second role of a certificate, namely it does not authenticate the user, because it is self-signed and cannot be externally validated.  This is not necessary with internal traffic, of course, because you know where it originated.  (Admittedly, in the age of “zero trust”, that might be becoming increasingly debatable).
Using an externally validated certificate would push the cost up, and hence everyone’s bill.  (As I said before, you have to pay for that validation).  More importantly, you do not need it to connect to an internal device as you know what and where it is.  Self-signed certificates have been used for internal traffic in industry for many years.  It’s just a shame no one has had the innovation to design a browser that can detect the difference between internal and external traffic.  And if there is not even a mechanism to accept the warning and connect anyway, that is a naïve short-coming of the Apple design, which I predict will cause a massive backlash.
Anyway, as has been said, this is a EE problem.  JimM11 and XRaySpecs will explain further, I’m sure.
Message 17 of 18
"Sorry, but that is not correct either. The certificate is self-signed, but it is used to enable secure connections - not just for "internalise".
Regarding Safari, that opinion is not relevant."
You posted asking for help and opinions and then rather rudely rejected all replies. If you're sure you know better than everyone else, why bother to ask for help?
Message 18 of 18
