Message 1 of 18
EE Smart Hub - Nolonger able to access hub over https using Safari on macOS
Safari will no longer allow access to the EE Smart Hub (platform details below).
The browser detects the issue with the certificate hosted on the hub when connecting using the HTTPS schema and then goes through the process of issuing warnings about the certificate. The browser then allows the connection, at which point the Hub prompts the user to switch to an HTTPS connection.
This has been the M.O. for some time; however, after applying recent security patches to macOS (also after a recent reboot of the hub by EE), instead of proceeding to the Smart Hub landing page, the user is returned to the Safari prompt concerning the certificate. There is now no apparent way out of this closed loop.
Platform:
ProductName: macOS
ProductVersion: 26.7.3
Safari: 27.2
SmartHub: v0.46.02.10311
17 REPLIES 17
Message 2 of 18
Re: EE Smart Hub - Nolonger able to access hub over https using Safari on macOS
Probably best to try a different browser. I've never been a fan of Apple's Safari. Firefox, Chrome etc work perfectly well on Apple devices.
Message 3 of 18
Thanks, but that is not a valid answer. See above.
Message 4 of 18
BT switched the hub to HTTPS to stop browsers barfing because of insecure HTTP connection. However as they didn't provide  an SSL certificate, it just means browsers now barf at lack of certificate instead. Ain't going to change, work around it.
Tags (1)
Message 5 of 18
That is not correct.
The EE Smart Hub does have a certificate. A certificate is a prerequisite for serving an HTTPS connection. It is a straightforward matter to inspect the certificate.
Further, please read my original post again.
Message 6 of 18
It's a self signed certificate.
In any case, you need to post on the EE forum
Message 7 of 18
The smart hub does have a certificate; it is just that it is a self-signed certificate for internal use.  A technique that has been used in industry for many years.  You have to pay a third-party for an external certificate.  Not worth the cost for a lot of situations involving internal traffic only.
Frankly, if the latest upgrade to Safari does not allow a by-pass for situations involving internal network traffic using a self-signed cert then I can’t see that being the death of Safari.  A lot of admins will give it up as too much of a pain in the a*** and switch to another browser.
Tags (1)
Message 8 of 18
I know it is a self-signed certificate. You said that there was no certificate, which is not true.
Message 9 of 18
Sigh
Tags (1)
Message 10 of 18
Sorry, but that is not correct either. The certificate is self-signed, but it is used to enable secure connections - not just for "internalise".
Regarding Safari, that opinion is not relevant.
