Message 1 of 4
EE Smart Hub2 and BT complete wifi
Hi,
Will BT Complete WiFi disks work with the EE Smart Hub 2.
or would I be better off extending my WiFi with a Netgear Extender booster EX3110?
thanks
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: EE Smart Hub2 and BT complete wifi
There is no EE smart hub 2.  They currently offer the smart hub plus  and the wifi 7 router.
The wifi discs will only work with the BT SH2.
Both EE devices are vastly superior to the current BT router so I doubt you'll need any sort of additional discs.
Message 3 of 4
Thank you.
BT have sent me an EE Smart hub.
It is marked as an SH20A
My query is whether or not Bt complete WiFi disks will be compatible as I live in an old house which has WiFi dead spots.
thanks
Message 4 of 4
Morning @K_H
Thanks for coming back to the BT Community.
Have you received the router and set this up to see if the WiFi discs connect?
If you have not received the router, please give our broadband tech guides a call and the guide can check if the router and WiFi discs will be compatible for you.
Thanks 🙂
Leanne.
