Message 1 of 5
Event log history
How long is the even history kept for on BT Homehub? How long can I see back as to has connected to my hub?
4 REPLIES 4
Message 2 of 5
Re: Event log history
Go to the first page and you will see.
Message 3 of 5
Thank you for the reply but I haven’t had it long enough to see that yet.  I wondered if there was a set amount of time that these events were stored for.  It’s actually a smart hub not a home hub.
Message 4 of 5
There won't be a time limit, it will be an entry limit.
The fewer the entries the longer it will take to fill.
Message 5 of 5
Thankyou
