midlife
Message 1 of 3
Extend the power cable to the whole wifi hub
I need to place a whole wifi hub in a place that is futrther away then the length of the power lead.
Not certain of the size and code of the male and female connectors but could I use this to extend the power lead which states universal extension cable for S1 B1 B2 series compatible with 12v power adaptor
Thanks Graham
2 REPLIES 2
JohnC2
Moderator
Moderator
Message 2 of 3
Re: Extend the power cable to the whole wifi hub
Hi @midlife You would be best to contact the product help desk. You can call them on: 0808 100 6116 Mon to Fri 9.00am to 5.30pm, Sat 9.00am to 2.00pm or drop them an email at: btconnectedhome@bt.com
cheers
John
midlife
Message 3 of 3
thank you will see what they say
Graham
