Johnston154
Newbie
Message 1 of 2
Extender flex 500! Help!
Hello - bt recently sent me flex 500 extenders. Not sure I understand how it works as a wifi booster - it appears it only works through Ethernet. So connecting one directly to your router and a socket then the other also on a socket then to your chosen device again connected by Ethernet. My question is can these be used as wifi boosters without Ethernet in the second extender? Thanks
1 REPLY 1
Message 2 of 2
Re: Extender flex 500! Help!
No, you need the Hotspot version which gives 2 Ethernet ports and wifi. http://www.shop.bt.com/mini-sites/connected-home/home-hotspots
