JonnyEdinburgh
Message 1 of 2
Extending a BT Mini Hub
Hi I already have a bt mini connector set up. I want to extend this to give Ethernet connection in another room. Can I extend this using the Flex 1000 kit? I have tried to connect but not working. I do not get a data light. Thanks
1 REPLY 1
NeilO
Moderator
Moderator
Message 2 of 2
Re: Extending a BT Mini Hub
Hi @JonnyEdinburgh welcome to the community and thanks for posting. Have you connected the Flex 1000 kit to a Mini connector via ethernet or have you connected them directly to a port on your Home Hub?
