Message 1 of 3
Extra box options
Hi
Apologies if this has been asked before, I am thinking of returning to BT and have a YouView box that I still use. My question is, I am trying to be as green as I can and wondered if there was anyway that this could be used as the extra box so that I can watch BT TV in other rooms?
Many thanks
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: Extra box options
Yes it can be used as an extra box, when ordering you have the option for the 2nd box subscription plus a BT supplied Youview box or just the second box subscription, the cost is £5 per month.
Message 3 of 3
Hi @Mull1974,
Thank you for posting.
What @-Richie- has posted is correct. You can find out more here BT TV Extra Box
Thanks,
Paddy
