Message 1 of 2
Extra box
If you choose an extra box for £5 extra per month in your new order, is this also a box that you can record to?
And as a new customer moving to a new build, do I need to have a loft aerial for the freeview  channels
1 REPLY 1
Message 2 of 2
Re: Extra box
Extra box subsription include a free Z4 non-recordable box, previously BT did allow customers to pay extra towards a recordable box but I'm not sure that's still an option.
You need to have a working aerial, most are in the loft or mounted to the roof but the location is only for a better signal, if it works and you receive freeview then you'll be ok, BT can also arrange an install for a one-off £40 fee
