Ibby
Newbie
Message 1 of 2
Extra whole home wi fi disc
Hi,
We have the Whole Home three disc set. It has been brilliant in our house that has lots of signal issues.
I want to put an extra disc in the garden room, at the bottom of the garden. This is too far from the nearest disc in the house.
I am thinking of putting an Ethernet cable in conduit to the garden room.
If I pair the new disc as per instructions on the app then connect to the router via my Ethernet cable will this work?
1 REPLY 1
peterh0001
Message 2 of 2
Re: Extra whole home wi fi disc
Yes it should do, you can have a mixture of wireless and wired backhaul. I have used Ethernet on all three of my discs.
Make sure you do not exceed the maximum cable distance and use Cat 6 cable.
Peter
