campbela
Message 1 of 2
Feature request - LED status per disc
Hi,
I had a hunt around but couldnt find anywhere to request features.
Overall, I am happy with the product.  It seems to do what I want it to do.  One thing that would be nice is the ability to chnage the LED status indicator per disc.  I have 2 discs downstairs (lounge and study) and 1 upstairs (bedroom).  I find the light quite distracting when trying to sleep (in the bedroom), even on its lower setting so I have had to turn it off.  This means that I dont get any feedback on the other discs.  It would be handy to control the LED on each disc.
1 REPLY 1
Luke0493
Newbie
Message 2 of 2
Re: Feature request - LED status per disc
White electrical tape should do the trick, Just put a tab on it and it won't be a problem?
And it shouldn't be too unsightly
Luke.
