Redkiwi
Message 41 of 90
Re: Firmware won't Update
Me too -  bought the 2 pack yesterday to replace powerline extenders. Wifi coverage is now great across the house, but I get the 'Update Failed - please check your internet and open the app again' message...
hamilti
Message 42 of 90
This started on Friday.  Clearly BT struggles to manage out of hours support which really does surprise me.  Very dissapointed - they've *almost* lost a returning customer - I bought the extender today :-(.  Can we at least expect it by tomorrow evening?
Dickytwo
Message 43 of 90
Hamilti, I absolutely agree and have sent an official compaint to BT. Mon-Fri 9-5 support it would seem on anything back-end in their datacentres.
Dan-O
BT Devices Expert
BT Devices Expert
Message 44 of 90
Morning all,
Apologies for the problems you've been having over the weekend.
We have investigated and found the problems were caused by a power outage at our externally hosted firmware server.
These have now been resolved and you can continue to upgrade your Whole Home Wi-Fi systems.
iancrosbie
Message 45 of 90
Just done mine now updated no problem ver 1-2-3 ver3
binky
Message 46 of 90
Confirmed...
Devices are now updating as expected and mobile apps continue past checking for new firmware.
Dbaplaya
Message 47 of 90
mines updated as well, but still unable to get past the screen to add more discs. I come to naming one such as Kitchen Lounge etc and it just says There is no response from your network.
This isnt good enough.
It isnt the discs as I had the same issue on the first lot.
Dan-O
BT Devices Expert
BT Devices Expert
Message 48 of 90
Hi @Dbaplaya
Have you contacted the BT helpdesk about your particular issue?
Dbaplaya
Message 49 of 90
Yes, last week, before I purchased the 2nd set and they said there were problems with the app and it would be fixed end of the month.
I thought it cant be app related as ive tried it on different platforms so it's either
my talktalk connection
the discs generally are faulty
BT server connection etc issues
All the apps are faulty
Dbaplaya
Message 50 of 90
Just on the phone to BT now
They said they cant help right now but there is an app update  end of the month which should sort it out!
Same response as last time.  This is a joke.
