Trivialis
Message 1 of 5
Flex 500 Kit
Is it worth swapping my Flex 500 Kit for the latest Flex 1000?
Jim
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Flex 500 Kit
Unless you are transferring large files across your local network, its not worth it, as your Internet connection speed is the limiting factor.
Devon_Dave
Distinguished Guru
Message 3 of 5
Re: Flex 500 Kit
Are you having problems with the 500?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
TimCurtis
Guru
Message 4 of 5
Re: Flex 500 Kit
Faster PLAs won't necessarily improve your speeds between devices as the quality of the mains circuitry can well be a limiting factor.
Trivialis
Message 5 of 5
Re: Flex 500 Kit
Many thanks to all.
