Murdo1
Message 1 of 3
Forwarding Ports on Smart Hub for Reolink NVR
Hi All
One last throw of the dice before I change out my smart hub in desperation.
Does anyone know any issues around smart hub blocking the use of forwarding ports 554,80, 9000 etc. I've set up the rule on the home hub. Selected upnp on the router advanced settings and same on IP camera software. Checked that rule is set up for local IP address connected to the ethernet that's going into port 1. Checked that the local ip matches with IP camera software.
Finally i used canyouseeme to check the ports and all showing closed.
I have read that there's issues with the smart hub but from experience these things are usually operator error. Any help much appreciated.
2 REPLIES 2
licquorice
Message 2 of 3
Re: Forwarding Ports on Smart Hub for Reolink NVR
Disable UPnP if you have manually forwarded the ports.
Murdo1
Message 3 of 3
Thanks for the reply
I deselected UPnp but still showing ports closed on twhen tested.
