Princessbetty
Message 1 of 10
G.P.O 250v ac
Hello every one,
does anybody know what this is? And can I remove it from inside my home?
9 REPLIES 9
lnajr02
Recognised Expert
Message 2 of 10
Re: G.P.O 250v ac
Yes its klaxon salve switch ( ringing converter that will switch a mains bell on and off) normally used in farms and big buildings.
The glass thing at the top is mercury so don't damage this...
Keith_Beddoe
Message 3 of 10
Re: G.P.O 250v ac
@Princessbetty
I would recommend you take the whole thing intact, to your local re-cycling centre, and let them deal with it. Make sure that you disconnect any mains supply feeding it first.
Those units were also used to power mains sirens for early warning systems. If its marked GPO, then it could have been there since WW2.
Princessbetty
Message 4 of 10
Re: G.P.O 250v act
Thanks for the replies, not sure if its powered but there is a cable that goes into a wall box like a switch plate.  The house was built in 1985 so rules out ww2
Keith_Beddoe
Message 5 of 10
Re: G.P.O 250v act
If there is so sign of a siren outside, then it could simply have been for an external bell, as @lnajr02  has said.
Similar devices were used to power sirens during the 1980s.
licquorice
Message 6 of 10
Re: G.P.O 250v act
As @lnajr02  said, it is for sounding a mains operated bell/klaxon. The incoming ringing current when a call is received operates the relay which in turn tilts the mercury switch which completes the electrical circuit for the bell/klaxon.
Princessbetty
Message 7 of 10
Re: G.P.O 250v act
Just taken another picture this unit sits under the gpo box, one grey power cable goes into the gpo box and the other cable as been cut
licquorice
Message 8 of 10
Re: G.P.O 250v act
That is device to provide a 50VDC supply to telecoms kit from the mains, probably a loudspeaking telephone No 4.
https://www.britishtelephones.com/lst4.htm
None of the kit is required today.
Princessbetty
Message 9 of 10
Re: G.P.O 250v act
Could it be part of a carelink intercom system for the elderly or disabled as there is a lot of retirement bungalows around all built in the mid 80's?
licquorice
Message 10 of 10
Re: G.P.O 250v act
Doubtful, the mains operated bells were usually outdoor bells that were used in noisy environments such as a haulage yard etc. The loudspeaking phone (if that is what the PSU was for) would probably just have been in an office. In any case it is all redundant kit and can be scrapped. Be careful with the mercury though.
The kit all pre-dates the eighties.
