campbela
Message 1 of 5
Guest network - no internet access
I have just setup my 3 disc Whole Home Wi-Fi.  Normal access works fine.  Connecting via the guest network results in a no-internet access message (in Windows) and no internet access.
The primary disc is connected to a Netgear GS748TP managed switch via ethernet.  The other 2 discs are connected via wireless.
There are about half a dozen other devices connected to the GS748TP via ethernet, including a Smoothwall firewall which is used access the internet.
The primary DNS server is the DNS server on a Windows domain controller because it is required for Active Directory.  The secondary DNS server is the Smoothwall server which is also the gateway.
Any idea why I cannot access the internet using the guest network?
Alan
4 REPLIES 4
Dan-O
BT Devices Expert
BT Devices Expert
Message 2 of 5
Re: Guest network - no internet access
@campbela
Hi,
Do you have your discs set to use static IP addresses? If so, this issue is fixed in next week's release.
If not - could you share more about your setup? Are your DNS servers in the same subnet as your Whole Home Wi-Fi discs?
Dan-O
campbela
Message 3 of 5
Hi,
Yes they are setup with static IP addresses.
I'll look forward to the next update.
Alan
campbela
Message 4 of 5
Update v1.02.04 build10 seems to have fixed my issue.
Dan-O
BT Devices Expert
BT Devices Expert
Message 5 of 5
@campbela
Great, thank you for confirming this!
Dan-O
