Wonder if anyone can shed any light on why my router is being told to reconnect regularly. I have copied the (hopefully) log events below. I rarely get more than a week's uptime and the router reboots at the same time/wifi disappears.
08:24:31, 05 Dec. | (256670.310000) PPPoE is up - Down Rate=43947Kbps, Up Rate=9999Kbps; SNR Margin Down=11.9dB, Up=7.0dB |
08:24:31, 05 Dec. | (256670.290000) CHAP authentication successful |
08:24:30, 05 Dec. | (256670.200000) CHAP Receive Challenge |
08:24:30, 05 Dec. | (256670.200000) Starting CHAP authentication with peer |
08:24:30, 05 Dec. | (256670.200000) PPP LCP Receive Configuration ACK |
08:24:30, 05 Dec. | (256670.190000) PPP LCP Send Configuration Request |
08:24:30, 05 Dec. | (256670.190000) PPP LCP Receive Configuration Reject |
08:24:30, 05 Dec. | (256670.190000) PPP LCP Send Configuration ACK |
08:24:30, 05 Dec. | (256670.180000) PPP LCP Receive Configuration Request |
08:24:30, 05 Dec. | (256670.180000) PPP LCP Send Configuration Request |
08:24:28, 05 Dec. | ath10: STA 04:d3:b0:31:23:51 IEEE 802.11: Client associated |
08:24:24, 05 Dec. | ath10: STA 04:d3:b0:31:23:51 IEEE 802.11: Client disassociated |
08:24:07, 05 Dec. | ath10: STA 04:d3:b0:31:23:51 IEEE 802.11: Client associated |
08:24:07, 05 Dec. | ath10: STA 04:d3:b0:31:23:51 IEEE 802.11: Client disassociated |
08:23:46, 05 Dec. | (256626.100000) CWMP: session closed due to error: Could not resolve host |
08:23:43, 05 Dec. | (256623.140000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username |
08:23:43, 05 Dec. | (256623.130000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
08:23:40, 05 Dec. | (256619.340000) PTM over DSL is up |
08:23:11, 05 Dec. | (256590.730000) CWMP: session closed due to error: Could not resolve host |
08:23:10, 05 Dec. | (256590.240000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username |
08:23:10, 05 Dec. | (256590.230000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
08:23:10, 05 Dec. | (256589.580000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
08:23:08, 05 Dec. | (256587.500000) PTM over DSL is down after 4275 minutes uptime |
08:23:08, 05 Dec. | (256587.500000) PPPoE is down after 4274 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] |
08:23:04, 05 Dec. | (256583.410000) PPP LCP Send Termination Request [User request] |
08:22:11, 05 Dec. | IN: BLOCK [16] Remote administration (TCP [46.101.35.88]:42771->[5.80.66.220]:8443 on ppp3) |
from your high noise margin it would appear the drops in connection are not the normal 7/14 day reset by DLM but more likely some line noise/interference
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results remember to delete number https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Quiet line test is quiet
stats are here
