Message 1 of 3
Halo 3 & Ethernet cable
Hi
Although I have wifi, for work I have to use an ethernet cable.
Rather that trailing an ethernet cable around the house, can I put a halo disc in the room I am working and plug an ethernet cable into the Halo 3 ?
2 REPLIES 2
Message 2 of 3
Re: Halo 3 & Ethernet cable
@Jacqui3
Yes, that should work just fine, provided the disc is within range.
Message 3 of 3
@Keith_Beddoe
thanks that helps,
