copthis1
Message 1 of 5
Help with Smart Hub 6
I have just set up my HH6 purchased from Ebay.  I checked the hub info and found this:
Product name:
BT Hub 6A
Firmware version:
SG4B10002236
This I believe is a very old firware version.  Should I update it, if so how and should I do a full factory reset first?
Answers in laymans terms please. Smiley Embarassed
Message 2 of 5
Re: Help with Smart Hub 6
In very layman's terms, you can't update it manually. It will get updated automatically at some point by BT if you leave it connected to your broadband.
copthis1
Message 3 of 5
So I could wait months?  I've got the 2016 firmware on it.............
Message 4 of 5
You will have to wait as long as it takes, there is NO manual method of updating the firmware, it will probably only be a few days though. Doubt if you will tell the difference in any case.
Message 5 of 5
If hh6 is second hand then I would factory reset it before using it. Won't update firmware but will give clean start
