Message 11 of 15
Re: . Hi I’m looking for the code to sync my tv it’s a jvc tv thanks
Yes that’s the same one
Message 12 of 15
Thanks for confirming this for us @Blackmole
The article does advise the box will no longer be supported.
You could try getting in touch and the team will see if they can suggest anything for you to try.
Leanne.
Message 13 of 15
Okay thanks
Message 14 of 15
No problem at all @Blackmole
Hope you get sorted 🙂
Leanne.
Anonymous
Not applicable
Message 15 of 15
@Blackmole
If possible, you should return it as very old & all but obsolete.
As for pairing the TV, JVC is just another brand that has long since ceased manufacturing its own TVs. I think the  brand name is currently owned/licensed to Currys, so maybe they can tell you who the actual manufacturer is. If there's a code listed for Vestel, that might be worth a try.
