Elevonic
Message 1 of 3
Home HUb 5 port forwarding
Hi all, I've just installed a Swann CCTV and trying to get access to it from outside of my home network. I've followed the steps to port forward 85 & 9000 but both still show as closed. I've set a static ip on the CCTV and I can ping it succesfully from within my network. I can see the CCTV from its app when I'm in my network. Any ideas? Thanks
2 REPLIES 2
Elevonic
Message 2 of 3
Re: Home HUb 5 port forwarding
Sorted! Turns out the ports were open but the CCTV had the wrong gateway address in it so they appeared closed.
RobbieMac
Moderator
Moderator
Message 3 of 3
Hi @Elevonic
Great to see you got it sorted.  Thanks for coming back on to let the community know the solution to the problem you were having Smiley Happy
Cheers,
Robbie
