I recently found out the HH4 has 1 Gigabit port, but I can't find any information about which one it is. Or is it something you need to set in the settings?
Solved! Go to Solution.
Thanks for your post and welcome back!
Have a look at the ethernet ports on the back of the Hub. The port that has "GigE" above it is the one you're looking for 😊
Cheers,
Robbie
Thanks for the reply!
However it seems like none of them are marked like that. It has "Gig Ethernet" above all 4 ports.
Edit: I'm an idiot- I now realise that it is a Home Hub 5 I own, not a 4. Does that mean they are all Gigabit?
Thanks for posting back @rainbowcemetery
Ah, I see. Yeah, they're all Gigabit on the Hub 5 😀
Cheers,
Robbie
