Velvetcoat
Message 1 of 2
Home Hub 6 SSID on 5G having superfluous -5 suffix
Has anyone found a way to remove the -5 suffix on the HH6 when using different SSID’s for each band? On my old HH4, I have, for example, adcde as 2G and wxyz as 5G. On the HH6 these become abcde for the 2G and wxyz-5 for the 5G. The -5 suffix is superfluous as only I know which SSID is which and only I need to know. The stupid thing is that if the SSID’s are not split the HH6 uses the same on on each network, which upsets some connecting equipment. I could understand having the -5 suffix then but definitely not if the the bands are separated.
If the HH6 cannot be instructed to allow the SSID I want, not what it wants, then I’m afraid it will have go back as it is, for me at least, unfit for my requirements.
1 REPLY 1
Message 2 of 2
Re: Home Hub 6 SSID on 5G having superfluous -5 suffix
