allanh
Message 1 of 3
Home hub 6 USB port
Can the USB port on a Home Hub 6 be used to power another device? I would like to power a Blink camera sync unit which needs to be positioned close to the router from the port. On previous BT routers I have had the USB port could be used to charge a mobile phone for example.
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: Home hub 6 USB port
Hi @allanh welcome to the community and thanks for posting, I've used it to charge portable battery packs and mobiles. The USB 3.0 port on the smart hub can provide up to 5 volts at 900 mA.
allanh
Message 3 of 3
Thank you Neil0 for your reply which is much appreciated.
Your answer means that I can have a much neater solution to my Blink camera set up.
