KF2
Newbie
Message 1 of 2
Home wifi disc
Hi everybody
My wifi disc dropped on the floor and lost one of its legs.
i tried to reconnect it, but i clumsily i pushed the platform+spring inside the disc.
i can fix it if i could open the disc in two.
Can i open this disc?     that's my question.
Many thanks
Mark
Tags (1)
1 REPLY 1
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: Home wifi disc
Hi @KF2
Do you have a black or a white disc? I assume black as it would be difficult to break the metal leg of the white ones?
Assuming you have the black disc that came with BT Plus and Complete Wi-Fi, I recommend you call the BT Plus helpdesk and ask for advice how to get a replacement. The number is 0800 800 150.
We don't advise opening products as there's usually very little you can do to repair and there could be risk of electrical shock if not done properly. Of course it's hard to advice specifically without seeing the product, but that's our general guideline.
Community ModeratorBrunoN
Show your appreciation!
Kudos”
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info.
