amacteaching
Message 1 of 4
Homehub 6 Firmware
My Homehub 6A has been running fine until monday morning:
Could I ask if anyone else had an upgrade at 8am on the 03/12/2018?
It is really annoying as the unit is now not at all happy!
Log attached - I have nothing to compare it with and the device is showing as upgraded on the 01-october-2018 to firmware SG4B1000B540.
Anyone out there know how to get a dump of caches beyond the log?
and the timing of the update.... surely not!
08:11:5903 Dec.ppp1:TR69 creating new session with ACS
08:11:5603 Dec.:The Modem successfully installed a firmware update
08:11:3103 Dec.:The Modem is installing a firmware update
08:11:2703 Dec.ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
Log extract follows:
00:01:4701 Jan.BR_LAN:The DHCP options that are offered by the device (id:4): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53555761505112 | RequestOption55: 11213615119252 | HostName: Andrews-iPad | VendorId:
00:01:4401 Jan.Smiley Very HappyHCP Confirmation of Request
00:01:4401 Jan.Smiley TonguePPoE connection could not be established. Login failed but there was no detailed information delivered by the radius server.
00:01:4001 Jan.pppSmiley TonguePP: CHAP_FAILURE
00:01:4001 Jan.pppSmiley TonguePP: CHAP_RESPONSE
00:01:4001 Jan.wl1:A WiFi device <1C:AB:A7:CA:BB:E1> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
00:01:4001 Jan.pppSmiley TonguePP: LCP_GOOD_ACK
00:01:4001 Jan.pppSmiley TonguePP: LCP_REQUEST
00:01:3501 Jan.Smiley TonguePPoE error: timeout
00:01:1901 Jan.BR_LAN:The DHCP options that are offered by the device (id:11): DiscoverOptions: 535557615112 | DiscoverOption55: 11213615119252 | RequestOptions: 53555761505412 | RequestOption55: 1
00:01:1401 Jan.wl1Smiley Sad1/11) Channel Hopping initiated/Manually initiated
00:01:1401 Jan.ptm0.101:VLAN VLAN_DATA connected
00:01:1301 Jan.Smiley Very HappyHCP Confirmation of Request
00:01:0801 Jan.:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:0801 Jan.:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:0801 Jan.dsl:VDSL link Up: Down Rate=31812KbpsUp Rate=5292KbpsSNR Margin Down=0.00dBSNR Margin Up=4.00dB
00:01:0201 Jan.wl0:A WiFi device <78:7B:8A:84:CC:4D> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
00:00:5301 Jan.eth1:[Device Connected] MAC Address:7c:2f:80:66:b1:8b Host Name: N300A-IP IP Address: 192.168.1.64lease duration is 86400 seconds.
00:00:5301 Jan.BR_LAN:The DHCP options that are offered by the device (id:8): DiscoverOptions: | DiscoverOption55: | RequestOptions: 535054601212555 | RequestOption55: 13615424312011466125 | HostName: N300A-IP | VendorId: N300A_IP
00:00:5201 Jan.BR_LAN:UPnP functionality has been activated
00:00:5101 Jan.Smiley Very HappyHCP Confirmation of Request
00:00:4301 Jan.:This Rule has been applied successfully: [id:1InternalClient:External PortsSmiley Sad00)Internal Ports: (00)Protocol: ]
00:00:4301 Jan.:Updating port mapping rule (1) by UPnP
00:00:4201 Jan.eth2:An Ethernet port is now connected (3/100/FULL)
00:00:4201 Jan.eth1:An Ethernet port is now connected (2/100/FULL)
00:00:4001 Jan.:The LAN DHCP Server is active
00:00:3901 Jan.BR_LAN: Revoked prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
00:00:3901 Jan.Smiley Very HappyNS name resolution is now active
00:00:3801 Jan.wl0:WLAN has been activated (BTWifi-X) (band : 5GHz).
00:00:3801 Jan.wl0:WLAN has been activated (BTWifi-with-FON) (band : 5GHz).
00:00:3801 Jan.wl0:WLAN has been activated (Hub6-8X92-5) (band : 5GHz).
00:00:3801 Jan.wl1:WLAN has been activated (BTWifi-X) (band : 2.4GHz).
00:00:3801 Jan.wl1:WLAN has been activated (BTWifi-with-FON) (band : 2.4GHz).
00:00:3801 Jan.wl1:WLAN has been activated (BTHub6-8X92) (band : 2.4GHz).
00:00:3601 Jan.Default:Firewall change to Level: FRWL
00:00:3601 Jan.wl0Smiley Sad0/36) Channel Hopping initiated/Manually initiated
00:00:3601 Jan.wl1Smiley Sad0/1) Channel Hopping initiated/Manually initiated
00:00:3501 Jan.:The Modem has successfully powered up
00:00:3501 Jan.:WDG Laststatus:: # Current boot was caused by Soft Reset (SAAF)
00:00:2801 Jan.:The Modem underwent a warm reset
00:00:2301 Jan.:WAN: ethernet as LAN
08:39:2603 Dec.dsl:VDSL Link Down: duration was 683777 seconds
08:39:2603 Dec.:VLAN VLAN_DATA disconnected
08:39:2603 Dec.:Timeout during PPP initialization LCP/IPCP
08:39:2603 Dec.ppp1:The DYN ROUTE [213.120.234.38/32 gw 172.16.19.188] is deleted
08:39:2603 Dec.ppp1:The DYN ROUTE [213.120.234.42/32 gw 172.16.19.188] is deleted
08:39:2603 Dec.:Connection to the Internet has been terminated.(RebootReconfigurationforced termination)
08:39:2403 Dec.ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
08:39:2403 Dec.:A device reset was performed (GUI/Button)
08:12:0403 Dec.ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
08:12:0403 Dec.ppp1:TR69 sending SetParameterValuesResponse message
08:12:0403 Dec.ppp1:TR69 receiving SetParameterValues message
08:12:0303 Dec.ppp1:TR69 sending SetParameterValuesResponse message
08:12:0303 Dec.ppp1:TR69 receiving SetParameterValues message
08:12:0303 Dec.ppp1:TR69 receiving TransferCompleteResponse message
08:12:0303 Dec.ppp1:TR69 sending TransferComplete message
08:12:0303 Dec.ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
08:12:0303 Dec.ppp1:TR69 receiving InformResponse message
08:12:0203 Dec.ppp1:TR69 event found : M Download
08:12:0203 Dec.ppp1:TR69 event found : 7 TRANSFER COMPLETE
08:12:0203 Dec.ppp1:TR69 event found : 4 VALUE CHANGE
08:12:0203 Dec.ppp1:TR69 sending Inform message
08:12:0103 Dec.ppp1:TR69 event found : M Download
08:12:0103 Dec.ppp1:TR69 event found : 7 TRANSFER COMPLETE
08:12:0103 Dec.ppp1:TR69 event found : 4 VALUE CHANGE
08:12:0003 Dec.ppp1:TR69 sending Inform message
08:11:2703 Dec.ppp1:TR69 sending DownloadResponse message
08:11:2703 Dec.ppp1:TR69 receiving Download message
08:11:2603 Dec.ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
08:11:2603 Dec.ppp1:TR69 receiving InformResponse message
08:11:2603 Dec.ppp1:TR69 event found : 4 VALUE CHANGE
08:11:2603 Dec.ppp1:TR69 event found : 2 PERIODIC
08:11:2503 Dec.ppp1:TR69 sending Inform message
08:11:2403 Dec.ppp1:TR69 event found : 4 VALUE CHANGE
08:11:2403 Dec.ppp1:TR69 event found : 2 PERIODIC
08:11:2303 Dec.ppp1:TR69 sending Inform message
08:11:2303 Dec.ppp1:TR69 creating new session with ACS
3 REPLIES 3
Dippu
Message 2 of 4
Re: Homehub 6 Firmware
Sounds like you have had a "downgrade" as well, see my post below.
I don't know the reasons but perhaps a BT Device Expert could answer the question.
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Strange-Firmware-Update-situation-on-HH6A/m-p/1...
Message 3 of 4
try a factory reset and see if that helps as possibly firmware did not update correctly
amacteaching
Message 4 of 4
Hi-
Can anyone please post me a log for a firmware upgrade for comparison purposes?
Many thanks
Andrew
