Hello I recently change my package with BT and I received a new home hub 6 I'm just wondering if anybody tell me if my stats look good also in the section where it says maximum data rate is that what should be achievable in a perfect world I've been on Infinity for a round 7 years . I did achieve speeds of around 80 meg in the beginning
Can you enter your phone number and post results remember delete number but leave exchange and cab.
https://www.btwholesale.com/includes/adsl/main.html
Hi thanks for the reply ...is this what you need
Yes but you have deleted exchange and cab number along with number
Sorry that was my mistake
I would have expected your connection speed to be nearer attainable You currently are below the bottom of estimated range and as cab ECI you currently won't get a boost from G.INP
are you using the test socket with a filter to see if that improves your speed?
any noise on phone line with corded phone?
I don't have a corded phone and I'm not plugged in to the test socket...I'll see if I can find a phone. I could try the test socket but I'm trying to see how reliable the hub 6 is at the moment . I'll give it a few days then try
