Woot025
Message 1 of 8
Hotspot 600 Wi-Fi speed
I have recently purchased the bt home hotspot 600 kit. The initial set up went fine but when I move the hotspot into any other room than the one containing the extender unit I am getting 2mps download speed maximum. Most of the time the device just drops out and I get a connection error. Any advice would be greatly appreciated.
7 REPLIES 7
licquorice
Message 2 of 8
Re: Hotspot 600 Wi-Fi speed
You could try changing the channel, but the range of the hotspots won't be great. Definitely make sure they are on a different channel to your Hub.
Woot025
Message 3 of 8
How would i go about changing the channel?
Keith_Beddoe
Message 4 of 8
@Dan-O may be able to help.
licquorice
Message 5 of 8
@Woot025 wrote:
236,509
I can't give you the exact steps involved as I haven't got a hotspot  600, but if you login to the hotspot there should be a menu option somewhere to change the channel. How to login is shown here http://btsupport.custhelp.com/app/answers/detail/a_id/45528/c/7187
licquorice
Message 6 of 8
It is also best not to clone the hotspot with your hub as it is then not obvious which device you are actually connecting to.
Keith_Beddoe
Message 7 of 8
@licquorice I see that quoting seems to be bust, I though it was just me. I will flag it up.
licquorice
Message 8 of 8
Thanks Keith.
