bingefeller
Message 1 of 6
How do I block a single site with the Smart Hub?
Hi guys,
How do I block a single site using the Smart Hub 6?  I don't want to turn on parental controls, just block one particular site.
Thanks!
5 REPLIES 5
Message 2 of 6
Re: How do I block a single site with the Smart Hub?
As far as I am aware you will not be able to block only one site at a network level with the Smarthub. You would need to use parental controls or buy a VDSLModem/router that allows you to specify and blck web sites individually.
Message 3 of 6
It can`t be done on any of the home hubs, but can be done on a third party £35 router. You can add multiple sites, and also restrict Internet access as well.
BT like to keep things simple on the home hub, so they can control it.
bingefeller
Message 4 of 6
Thanks guys.  It's a bit disappointing that I can't restrict access to a particular site.  I'm very happy with the HH6 otherwise.
Message 5 of 6
BT network based Parental Controls will allow you to add a site that you want blocked, but it will affect all devices connected to your network.
See https://community.bt.com/t5/Home-setup-Wi-Fi-network/Is-it-possible-to-block-an-IP-address-from-my-n...
bingefeller
Message 6 of 6
Thanks, I will try this - it looks like it will work after all.
Many thanks, Keith!
