Message 1 of 6
How do I get a returns bag for my BT TV Equipment?
Hi , I cant find the link for the return equipment?
Could someone help?
Many thanks
5 REPLIES 5
Message 2 of 6
Re: How do I get a returns bag for my BT TV Equipment?
Could someone help?
Many thanks
Have you been asked to return it?  When was it originally issued to you?
Message 3 of 6
It was originally issued to me in 2020, I havn't been asked to return it , but the website does say they will charge me ?
Message 4 of 6
All BT equipment issued after 13th Dec 2019, is only loaned, and would need to be returned if you leave BT, otherwise you could be charged.
https://www.bt.com/help/tv/how-to-return-and-recycle-your-bt-broadband-hub-and-bt-tv-box-fo
Message 5 of 6
Thank you , I found this information , my problem is I have spent over an hour looking for the return equipment link and it does not seem to be there ??
This does seem to be a recurring issue from the conversations in the forum.
Message 6 of 6
Hi @Lizzie235 Thanks for your posts, I'm sorry to see you've been unable to order returns packaging on MyBT. I've sent you a private message so you can get in touch with the moderation team and we'll be happy to help.
Neil
