thos_tanner
Message 1 of 2
How do I manage a bt minihub
We have a bt minihub connected to our smart hub. I thought I'd see the devices connected to my minihub appear on the ethernet port to which the minihub is connected, but they're just not appearing. And I can't find any way of going onto the minihub and finding out what it thinks it has connected directly to it. the web page just allows you some basic configuration.
1 REPLY 1
Message 2 of 2
Re: How do I manage a bt minihub
To the best of my knowledge the mini hub and all the other hot spot range do not show the devices connected to them
