Pammiej
Message 1 of 3
How do I turn off the handset light whilst it's on the base unit
Hi
I have a bit 2700 and the handset light is very bright whilst it's on the base unit. I have tried turning the backlight off but when I replace it on the base unit it comes back on and is very bright
2 REPLIES 2
JohnC2
Moderator
Moderator
Message 2 of 3
Re: How do I turn off the handset light whilst it's on the base unit
Hi @Pammiej Check out the user guide for the BT2700 Nuisance Call Blocker guide which I think is the phone you are referring to. The link also has details for the product helpdesk if you can't find an answer to your question give them a call.
Cheers
John
BrunoN
BT Devices Expert
BT Devices Expert
Message 3 of 3
@Pammie, hi, sorry I missed this question earlier.
I checked with the product team and unfortunately there isn't a way on this model to dim the screen whilst charging.
