Solved! Go to Solution.
Hi @Pammiej Check out the user guide for the BT2700 Nuisance Call Blocker guide which I think is the phone you are referring to. The link also has details for the product helpdesk if you can't find an answer to your question give them a call.
Cheers
John
@Pammie, hi, sorry I missed this question earlier.
I checked with the product team and unfortunately there isn't a way on this model to dim the screen whilst charging.
