Message 1 of 5
How do I unblock my new BT phones?
I bought a BT Advanced Phone - Two Handsets - in February.
I've been told by a friend that when he phoned me just now there was something that told him there was a call-blocker in place. He also said that the phone only rang three times before the call-blocker kicked in.
How do I remove the call-block and also set the phones to ring seven times, not three?
Tags (2)
4 REPLIES 4
Message 2 of 5
Re: How do I unblock my new BT phones?
can you not remove call blocker using the menu on your phone?
Message 3 of 5
Hello. I've checked all the settings and I can't see anything in the menu relating to call blocker. Nor anything enabling me to increase the number of rings before the answerphone kicks in.
I went to 'Menu>Answer Phone>Settings>Ring Delay and was baffled by the next options viz 'Answer Only' & 'Ans & Record'. BUT at this point I'm giving up. :o((     The menu on the screen disappears after two or three seconds & I'm constantly forced to start all over again.
So may I ask an even more important question at this stage? Is there any setting that I can change to keep my screen showing all the Menu etc results for a much longer time?
Oh, and there was another problem. I was asked on several screens to input my PIN number. I was never  given a PIN number when I opened the instructions.  Some PIN-protected equipment gives you a PIN number and demands that you change it immediately but there were no instructions about this in the box.
Message 4 of 5
Hi @Taffy078
The ring delay settings (2 - 10 rings) is on page 37 of your user guide.
The Call Blocking settings appear when you press the Block key. I switch it off when I expect a call back like from Amazon customer services as it is not a human calling you initially.
https://shop.bt.com/content/uni2/documentation/d9r4/advanced_phone_user_guide.pdf
Message 5 of 5
I wasn't sent a User Guide so thanks for the link. I'll read it now to see if I can remove the call-blocker.
