itm60
Message 1 of 6
How many versions of BT Whole Home Wifi?
I was thinking of buying a second-hand BT Whole Home Wifi kit, and was wondering if there was any potential drawback to buying older equipment - has the hardware been upgraded since it was first introduced?
5 REPLIES 5
BrunoN
BT Devices Expert
BT Devices Expert
Message 2 of 6
Re: How many versions of BT Whole Home Wifi?
Same hardware all along. All updates have been done in software.
Hope this helps.
itm60
Message 3 of 6
Great - thanks for the info
L60mcm
Message 4 of 6
Hi just checking that this is still the case
thanks
Darren_B
BT Devices Expert
BT Devices Expert
Message 5 of 6
Hi @L60mcm,
The hardware for each of the WHW variants (Standard, Mini, Premium) remains the same in regards to their main components (e.g. Memory, Chipset, Antennas, etc.) - there is no increased performance/spec in buying newer hardware over older hardware.
The most notable change in the hardware is the change to the new BT logo.  But that's purely a cosmetic change.
Hope that helps
Darren_B
L60mcm
Message 6 of 6
Thanks for getting back to me.
