erotavlas
Message 1 of 8
How to discover device detail from serial number
Hi,
I would like to obtain the production year of my bt home hub 5 from serial number. Is it possible?
Thank you
Tags (2)
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: How to discover device detail from serial number
Hi @erotavlas,
I'm not aware of anyway obtaining the production year of your Hub.
What is it you are trying to do?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
erotavlas
Message 3 of 8
Hi,
I would like to discover if the device is broken. I'm wondering to know how old it is even if I bought it 5 months ago on Internet. I discovered that into the power supply there is the production year and month 1634 -> 2016 and 34 week. So maybe also the device is of the same time.
TVrepairman
Message 4 of 8
Look at the serial number. For most boxes it will be something like this:
+077329+1548012345
The two digits after the second + indicate the year and week, for example 2015 week 48.
erotavlas
Message 5 of 8
My serial number is: +068343 + NQ40137890.
What is the the production year?
Message 6 of 8
I am curious how knowing the year the device was produced or how old it is will tell you if the device is broken?
It could have been produced two years ago but never been used until you purchased it.
Message 7 of 8
@erotavlas Are you using it on a BT broadband line? If not, it won't work, home hubs are locked to BT.
erotavlas
Message 8 of 8
Hi,
I installed the openWRT firmware and so it is unlocked. It works well, I just wonder to know the production year.
